You'll have two essential questions about hardtail bridges. The first is: vintage or modern spacing? Vintage is
about 57 mm, 2 1/4". Modern is
about 2 1/8", 54mm. There's still some variation between brands. The "modern" fits standard humbucking pickups better, though now there are "F-spaced" humbuckers from DiMarzio and others. The vintage (wide) spacing is easier to play for fingerpicking, but the strings are closer to the edges of the neck. The narrow spacing feels more normal to a Gibson player and it
might be easier to play quickly with a pick on one. I
personally prefer the modern, like the (post-1988) American Standard Fender bridge, that Gotoh pictured above, and many many others - I
hate pulling strings off the fingerboard. :sad1:
The second big question concerns the bridge "saddles", the doodads the strings go over. The newer bridges mentioned above have solid metal pieces, and the vintage style is the traditional bent-metal pieces - toneheads will argue long into the night (give 'em some likker, jeesh!) about the advantages of the bent metal pieces, it's sufficient to say that most of the great Fender sounds you've heard have been those - because that's all there
was on guitars for 25 years. The solid metal pieces are good enough for Jeff Beck, Sonny Landreth, Jimmy Herring, Billy Gibbons, ummm... my personal opinion is that lighter-weight bridge components are far more important on whammy bridges than on hardtails, because
I think the great weight debate is more of an issue of
balancing light-with-light & heavy-with-heavy rather than didactic "truths." But what do I know.... (not
enough likker?
). There was a move to put great weighty slabs of brass all over the place in the 1970's and it seemed to work fine on 13 lb. solid rosewood, cocobolo & hippie sandwich guitars while it assassinated the tone of featherweight Strats.
Ha Ha! Go ahead - ask a question about guitars - any question - ummm - gee, there'll be some opinions... :hello2: the Gotoh, Callaham, Fender, Schaller, bridges will all work really well for the first decade or so at least. The third main question is: Strings-through-body or top-mount? It probably doesn't matter, but so many people will tell you it does you should just get a strings-through bridge just to quell your own brain weaslies.
So that's why I said there are only
two questions. :headbang:
