pscates said:Dumb question, but where is the input jack for the DK24? Isn't on the front or the usual side areas (unless, for some reason, it's been Photoshopped out), so I imagine it must be tucked away on the rear somewhere (and in such a way that the cord isn't going to poke into your tummy or jewels)?
The input jack is one of the only things I don't like about them. It is a Strat top-mount jack, which has been mounted on a bevel in the back. This is a classic case of getting too creative. Please just give me a side-mount jack...like all my other guitars. That way I can just continue to use the same right-angle cable. A right-angle cable with this design is a no-go. I suppose if your other guitars are all S styles, and you're generally using a straight cable anyway, then maybe you'll appreciate this design.
