clbraddock
I have a two pickup strat (neck and bridge) that I only need one tone knob for. I was trying to decide what to do with the other tone knob and thought about adding a bass roll-off. G&L has a PTB (passive treble bass circuit) that does this, but I'm wanting to keep the treble tone control closer to the original wiring, i.e. one side of a 250k pot through a cap to ground. I'd also put the bass portion of the circuit on a DPDT switch so I can bypass the signal around it when not in use.
The original PTB circuit is here: https://tonefiend.com/guitar/two-ban...cheap-awesome/
I've attached a crude drawing of what I want to do. Will this modification work okay? (Mostly I'm asking about the change to the treble control)
Edit: I'd be using a no load pot for the treble pot (P1) if that makes a difference.
