JaySwear said:maybe even pearloid?
jalane said:BTW, Kisekae is AWESOME! The last thing i needed was another guitar-related internet activity to waste time...
bagman67 said:I like your taste for the old school colors with modern technological touches, Jalane. This should be a nifty axe.
Bagman
JaySwear said:i have an entire folder on my mac with probably 20 or 25 different mock ups :icon_biggrin: as soon as i realized i could copy image locations and paste them into the "DIY Body Finish" or "DIY Fret Board" i started copying and pasting warmoth showcase pieces into my kisekae builds. this one was a telecaster deluxe body that was in warmoth's showcase. it's even more addictive this way!
jalane said:![]()
:icon_thumright: I think this is happening
And yes, I'm painting the tele coral pink. Deal with it.
kboman said:Dude, you're painting a Koa tele solid pink?! Nando is going to murder you :toothy12:
dNA said:pardon my ignorance, but how would an on/off switch enable you to add the bridge pickup while the neck pickup is on. Whether it's on or off, it's not being selected. Or rather than an on/off switch, would you have a switch that essentially routes the bridge pickup to either the front or the back end of the 5-way? that might work, but it wouldn't be an on/off switch
drewfx said:If you wire the output of the push-pull to the neck "input" of the 5-way, you don't get the duplicate positions (i.e. position 3 stays mini HB alone).
jalane said:drewfx said:If you wire the output of the push-pull to the neck "input" of the 5-way, you don't get the duplicate positions (i.e. position 3 stays mini HB alone).
Oh ok, maybe that's what my friend was talking about. I couldn't remember the specifics of what he did with his strat, but i bet that was it. That way it would still function in positions 4 & 5
dNA said:jalane said:drewfx said:If you wire the output of the push-pull to the neck "input" of the 5-way, you don't get the duplicate positions (i.e. position 3 stays mini HB alone).
yeah. that's more what I was imagining.
so would you have the neck reverse wound like a standard tele set? Does this cause any issues when combining with the mini hum? I know the issue with trying to use neck+bridge in a setup comparable to a strat is that they aren't reverse wound so they cause a lot of noise or something like that.
I'd be curious to know if you could do anything that involves splitting the mini hum so you can combine one coil with bridge or neck pups - this would give you those strat-like in between tones that could be really sweet. but it may not be doable, or require more complex setups.
jalane said:And i think you're idea about the the split hum for in-between settings is really intriguing. I don't see why it wouldn't be doable as long as the mini humbucker had 4-conductor leads, right?
BTW, thanks for taking interest in this and helping me think critically about the specifics of my plan. This will be extremely valuable when it comes time to actually execute these ideas. :icon_thumright:
