I know (now) that you need to widen the holes slightly to fit the thimbles for a Mastery bridge into a Warmoth JM body, but how tight should the fit be for them? I would assume VERY, but a post on the Offset Guitars forum says that Warmoth had suggested that they be a loose fit, loose enough to fall out if the guitar was turned over. A vast majority of the other advice I've seen with this combo of parts seems to indicate a snug fit, but was curious if anyone here had more insight.
Thanks!
Thanks!
