Thank you.
Great idea to use the temp and humidity gauge. I have a couple for monitoring humidity in the house and in my guitar cabinet, but wouldn't have thought to use it during sealing or painting. Great idea. Will do definitely do that.
Thanks.
Thanks.
Cagey said:If I remember correctly, they already thin the stuff for spraying. That could just be the formulation StewMac distributes, for profitability's sake. But, you sorta have to shoot some and see how it behaves to know if it needs to be changed. The formulation makes a difference, as does the temperature, humidity and how you've got your gun/compressor set up.
If after an hour or so it still feels a bit rubbery and doesn't want to sand without loading the hell out of your paper, it's too thick and you need to add some acetone. If it runs/sags too easily, it may be too thin or the temperature may be too low. If the temperature is high, you may need to add some retarder to slow everything down.
It's a feel thing. This is why everybody will tell you to practice. Also, it's handy to have some instrumentation around. A temperature/humidity meter is a wonderful thing, and they're not expensive. For example, Honeywell sells these units...
... for $23. Tells you the temp in F or C, as well as the relative humidity. You gotta know that stuff.
