Max said:212 degrees farenheit.
dbw said:A mahogany strat is just warm enough. Add two humbuckers, a TOM, and a rosewood neck and you're in business.
uOpt said:Remember, everything changes everything.
uOpt said:dbw said:A mahogany strat is just warm enough. Add two humbuckers, a TOM, and a rosewood neck and you're in business.
If you do that, all you get is a murder boomy piece of guitar. Combine it with a SD '59 in the neck and your audience files complaints against you with the United Nations, for dehumanizing cruelty or something.
The Strat shape with it's large horns is only suitable for hardtailing with some kinds of wood. Certainly not light ash or alder. Heavy Ash seems to do better. Mahogany might be good. Or not. Poplar probably is, the Music Man Morse signature comes out good.
That's not what I've seen here.GoDrex said:I don't think the general consensus is that everything other than the neck and pickups is irrelevant. I think that the general consensus seems to be that the body wood is far less important than those two things (unless the body is chambered). I also don't think anyone that knows anything would argue that the type of bridge is irrelevant, or pot values are irrelevant. Everything has some effect. Some effects are more noticeable than others.
Superlizard said:That's not what I've seen here.
AToE said:I play mahogany strat (G&L F-100II) with a hardtail and it's the clearest brightest guitar I've ever played
GoDrex said:Well you know all, so perhaps I've been hanging out at a different board the past year or so...
