les paul dc style warmoth??
Muse_lover said:
I'm willing to spend an absolute maximum of $1,200, pickups n all. but I also want it to be quite unique.
I'd say $1200 is probably good to go for a LPS Flatop with Warmoth finish and DIY Maple neck or non-finised exotic.  The things that might push it over that amount is how fancy a top you get if applicable, binding if applicable, what kind of neck, and boutique pickups if applicable.  $1200 is certainly doable.
Put the pencil to it.  $1200 is a realistic budget if you don't get too fancy with extras.  They will nickel and dime you real quick.  You know what you want and don't want, plus all the prices are out there.
thanks....now, that fancy 'fireburst' finish seems a little less realistic.
Keep trolling ebay for used Duncan / Dimarzio / etc. pickups, you can usually pick up a pair of good humbuckers for $100 or so, that should help with costs. GFS makes inexpensive pickups too, some people love them. Pickups are easy to change later on, anyhow.
Tuners can be a good deal on Ebay too, Stew mac has the specs for the major brands, or just get the Gotoh sg38 that Warmoth sells, they are great for non-locking. Maple neck with a homespun finish adds character too.
Remember that if you don't know how to set up a guitar, including nut work, you need to either learn, and get a few simple tools, or pay someone who may or may not be a slacker hack disguised as a "luthier". Just thought I'd throw that out.
Patrick said:
All our necks are dipped in an oil based penetrating sealer which is compatible with virtually all secondary finishes. This provides enhanced stability; however, it is not adequate protection for playing. We strongly recommend you apply a hard finish to all Maple, Mahogany, and Koa necks. Oils do not validate our warranty requirements. We understand the attraction of raw or lightly oiled necks. They feel fast and are not sticky. Unfortunately, they are much more susceptible to moisture related warping and twisting.
i got that from the warmoth section on neck finishes
Tru-oil is an acceptable finish.  Tung oil is not acceptable.
