Muse_lover
Hi, I;m on quite a tight budget and want to make an lp dc pro style warmtoh. any tips on how to keep the cost down low??? thanks!!!
tfarny said:Agreed. In my experience: $600 is the cheapest you can possibly make a warmoth using good quality parts - pickups etc. $1000 puts you in a much sweeter spot. $1500 gets you anything you want except the top figured pieces. When you consider a les paul studio or american standard strat goes for about a grand new, those are great prices, but if your budget is $400 get an epiphone off of craigslist, a fret job and a pickup or two.
tfarny said:and the $600 is DIY finish, cheapest available showcase body / neck, and mid-level (but very good) parts - Gotoh/Duncan, not Callaham/bare knuckle. Helps if you have a few pieces already laying about, too, or if you can scavenge pickups off a current axe that you like.
Muse_lover said:Is unfinished maple ok?? I'm splashing out on the body, need to cut costs drastically.
Patrick said:but tru-oil finishes aren't covered under the Warmoth warranty
All our necks are dipped in an oil based penetrating sealer which is compatible with virtually all secondary finishes. This provides enhanced stability; however, it is not adequate protection for playing. We strongly recommend you apply a hard finish to all Maple, Mahogany, and Koa necks. Oils do not validate our warranty requirements. We understand the attraction of raw or lightly oiled necks. They feel fast and are not sticky. Unfortunately, they are much more susceptible to moisture related warping and twisting.
