Aussie Pete said:
Pickup gurus like Bill Lawrence tend to concentrate on the inductance of a pickup rather than other readings, as an indicator of the pickup's performance. Now, I barely know what inductance IS, let alone it's relevance to an electro magnetic passive pickup & Bill's own website has an article from him , plus there's his transcribed comments in the Wilde Gate forum, but I have read & re-read that & still shake my head wondering 'wtf'......Maybe some of you could explain the relevance of inductance to a pickup as opposed the voltage or resistance? :dontknow:
(Sorry if I have 'set the cat loose amongst the pigeons' here with this comment)
Inductance is a huge subject. Many books are written and classes are given on that all by itself. But, I'll try to keep this breif.
Inductance is the only reason a "traditional" passive guitar pickup works, so it
is kinda important <grin> Coil resistance is just a peripheral characteristic. Given a perfectly drawn wire of a given alloy, you can predict its resistance per foot surprisingly accurately. So, if you know what the total resistance of a coil is and the unit resistance of the wire, you can tell how many feet of wire are wound on a pickup, plus or minus some margin of error. But, that's about all you can tell. If it's a thinner wire, then it'll have a higher resistance than a thicker one, so the same total coil resistance can mean a great deal of difference in the number of winds on that coil, which changes its inductance and impedance dramatically, and consequently its frequency response and output level.
To "induce" simply means "to cause, influence or force". In electrical terms, you have inductors that induce currents. The manner and degree they can do that is often called "inductance". Most of this has to do with magnetic fields.
Any time you have a current flow through a conductor, you build up a magnetic field around it. The inverse is also true - any time you have a changing magnetic feild near a conductor, you induce a current flow. That's the magic that makes transformers (and pickups) work. You take a conductor (usually wire) and wind it around a magnetically permeable metal core (usually iron or steel). Run current through the conductor, and a magnetic field builds up in the core. Take the current away, and the magnetic field collapses, inducing a current in that same wire. Now, if there's a second winding of wire, there will be a current induced in it as well. That's where the terms "primary" and "secondary" windings come from.
In a typical transformer, like the power and output transformers in your amplifier, you don't usually open and close circuits except to turn the whole thing on or off. But, the current that flows when it's running is constantly changing direction because it's AC (alternating current). So, we get the same sort of effect. The magnetic field is building and collapsing all the time in that transformer, so current is being induced in the secondary winding(s).
How many windings, the ratio of windings between primary and seconday, the size and permeability of the core, and the size of the wire used to make the windings will all conspire to change the behavior of a transformer.
Pickups are essentially just transformers that are configured in a strange way.
Instead of running a current through a primary winding to generate a magnetic field, they use permanent magnets as the primary winding. Then, they use the guitar string as the core, then about a bajillion winding coil as the secondary. By moving the core (string) around in the magnetic field, it induces a current in the secondary. Amplify that, and you have a fairly accurate representation of the core's (string's) vibrations.
So, size of wire, number of windings, permeability and size of core, strength of magnetic field all work together as an inductor whose inductive characteristics produce a given result. And that's how babies are made <grin>
