AutoBat said:voltage & resistance? sounds like Ohm's law, which I was never really good at. Fairly sure you need 2 knowns to calculate a third though. (current?)
http://www.allaboutcircuits.com/vol_1/chpt_2/1.html
DMRACO said:how many mV is 15.8k? Is there a formula to use?
Super SauroPOD said:DMRACO said:how many mV is 15.8k? Is there a formula to use?
Too many.
If you're talking pickups that is.
8k is the sweet spot.
DMRACO said:OMG...sorry I did not get my PhD! :laughing11: I am simply tring to figure out the output of a semour duncan pickup. I am used to mV. They only provide k...15.8 in this case.
Alfang said:Not only what everyone else said , but also, the output of a pickup depends on the circuitry of the amp as well, when you plug in your guitar to an amp you are basicaly completing a part of a larger circuit
Napoleon's Uncle had a time machine, perhaps you can find one on the internet like he did. :tard: :laughing7:DMRACO said:Now is someone can just explain the possability of TIME TRAVEL to me so I can go back and buy a '52', '57 thru '60 Les Pauls new that would be great.
tfarny said:15.8 k dc resistance is probably a really hot pickup. In general I'd expect to be midrangey, loud, lacking dynamic range, and to not clean up well. That is assuming it's got a pretty standard type of construction. Does that help?
