three packages were shipped to me today...here are the specs of the planned build, and photos after
body:
solid body
wood - swamp ash
orientation - right handed
control cavity - rear route
pickup routes - Dimarzio Will Power Model One in the mudbucker position, Dimarzio Will Power p pickup in the standard p position, and Dimarzio X2N-7 humbucker in the bridge position
f holes - none
controls - mini toggle 3 way switch for tone cut/volume pot for Model 1/concentric volume pot for P and X2N-7/tone pot for P and X2N-7/ 3 way toggle switch (series/parallel/single coil) for coil tap for X2N-7
input jack route - two outputs secured to this output plate - http://www.guitarpartsresource.com/images/large/SMJP-B.jpg. it measures 2-3/8" x 1"
bridge - Badass III string thru body
mounting holes - standard 4 bolt pattern
contours - tummy cut and forearm contour
binding - none
stud install - n/a
battery box route - none
finish - sunset orange
neck:
p bass style
wood - canary for neck and fingerboard
nut width - 1 11/16"
back contour - standard
fingerboard length - 21
binding - none
fret size - SS6115
tuner hole - hipshot ult lite (14mm) with hipshot D-Tuner
inlay - black blocks
string nut - Graph Tech Black TUSQ XL
finish - n/a
electronics/hardware:
Mudbucker position - Dimarzio DP145 Will Power Model One
middle position - Dimarzio DP146 Will Power Model P
bridge position - Dimarzio X2N-7
body:
solid body
wood - swamp ash
f holes - none
binding - none
stud install - n/a
neck:
p bass style
binding - none
fret size - SS6115
finish - n/a
