Hey guys,
I'm in the process of assembling a carved-top Telecaster, and I'm having problems getting the jack to fit. This body has a 3/4" jack routing, and a standard Switchcraft mono jack will not fit through the route. If I really push on it, I can wedge it in there, but there's no way it'll fit with the wires soldered on. I don't think the route should be this tight, am I using the correct type of jack?
Also, the football jack plate isn't quite curved enough to fit. It's probably close enough, but it might not sit perfectly flush. Would I be better off using a square jack plate? Any help would be appreciated. Thanks.
