Pestymonkey
Hi guys,
How do I go about putting in the screws for the tuners, strap pegs, string retainers and the claw screws for the tremolo? Do I simply use a drill to make a pilot hole slightly smaller than the screw I'm going to put in and then screw the screws into the pilot hole? Should I use wax on the screws? Does the pilot hole need to run the whole depth that the screw will be in?
With string retainers, do warmoth pro necks already have the mouting holes for these or do I do this myself? If I do it myself, is there a set distance from the nut they should be, or is it just far enougth to add tension to the nut to ensure the strings don't slip out?
Also any tips on how to do the drilling (fast drill speed or slow, how to ensure the drill doesn't slip or splinter the wood)?
Thanks
Thanks
