Super Turbo Deluxe Custom
Epic Member
Also, Carvin does sell discontinued models direct on Ebay. Their BR615C has 400w at 4ohms, 600w at 2ohms. I have the head that is in this combo amp - BX600, it was good enough to keep. Most times I just used (1) 4ohm cab and 400w and never used all 400w. It has all the features of the BX500 (except for the switchable 12AX7 preamp) and a few more. The effects loop can be turned off, has a peak indicator, and the DI has a pre/post, but I always use the pre anyway. The mute function and built-in compressors on both the 500 and 600 are the great things on it. Once you play with a compressor, you'll wonder how you ever played without one. The 9-band EQs on both are little redundant IMO, but they are switchable so it in effect can be used as a boost function or treated like a second channel. As far as the sound you're looking for, with everthing flat, using the contour knob to scoop the mids is simple enough w/out even messing with the EQ. Or you could set contour to zero and boost the mids with either or both EQs. Those are you 3 bass sounds: scooped mids, flat, and boosted mids and an EQ to season anything else to taste.
http://cgi.ebay.com/CARVIN-BR615C-1x15-600W-Bass-Amp-Amplifier-Combo-NEW-C_W0QQitemZ150416810488QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item23058a61f8
