Hey guys,
Good to see a forum here. Lots of great info. My Iceman is done and I have been playing it quite a bit. A few things I will share with everyone.
http://www.warmoth.com/gallery/images/misc_guitar/P6010663.JPG
It's done in Tru oil, which was really friendly to work with. 4 coats, 0000 steel wool between coats. I didn't fill the grain, I wanted to go with an open grain look. I like it. Next one will be grain filled, to keep things different.
The neck is not stained, just mahogany with Tru oil. I should have filled the grain on this, I can feel the grain, even after fine sanding, in a few spots. Most wouldn't notice it, but it's starting to bug me so I may pull it off and strip it down and fill it. Not a big deal but food for thought for anyone planning a similar finish on a neck.
Like a dumb-a_s I scarred the back side with the soldering iron. Steel wooled it just a tad and wiped some Tru oil on it, can't even tell. Repairs well.
Set-up- I have a recessed Tonespro string thru body. I love the feel, but I am a little concerned about the saddle pressure. There isn't much angle there from the ferules to the saddles, and when I wipe my strings down after playing, I can pull the strings off the saddles really easy. I use 9's usually, but I am thinking about 10's.
Relief- I have enough relief to keep things from rattling, but the truss rod is barely tight. Again, 10's might be the ticket here. I like it low, so with a touch more relief I can drop the bridge down just a hair and not fret out on bends on the high frets.
Planet waves tuner - love them.
Pickups - Duncan Pearly Gates bridge, A2pro neck. Awesome classic/hard rock tones. This guitar sounds amazing. And with parallel, splitting, and out of phase, it does it all. My wife said it is "the most beautifull sounding guitar I have ever heard". And I have a few, so that says alot.
The standard thin conversion neck is awesome. Feels like an old friend. Not so with my ESP Viper 1000- wide and flat on the back side - I cramp up after awile. This one is really comfortable. OK, enough babble from me. :headbang1:
