Thanks!
For those that might wonder, yes, the threaded inserts are slightly offset. The back of the guitar has a round over and I wanted the bolts to be on the flat part.
To make the control cavity, I first made some templates from MDF. I got about half way down, but didn’t want to rush it. The rest of the way I can just use the cavity itself as the template. Going with a solderless electronics solution. Last night I took about an hour to carve a belly cut. Very satisfying. Just a rasp, a file and some sandpaper.
To make the control cavity, I first made some templates from MDF. I got about half way down, but didn’t want to rush it. The rest of the way I can just use the cavity itself as the template. Going with a solderless electronics solution. Last night I took about an hour to carve a belly cut. Very satisfying. Just a rasp, a file and some sandpaper. View attachment 68384View attachment 68385View attachment 68386View attachment 68387
If you are going to do something, might as well make it more difficult. The body was still a little heavy, so I added lightness by subtraction. Final body weight is 5.2 lbs.
99% complete. I say 99% because I’m not crazy about the plastic pickup covers, so I’m gonna fashion something to match the neck. Plays great. As a bonus, I put the 4 builds I’ve done the last 18 months on the wall together to get a glamor shot.
