WindsurfMaui
I hate Phillips head screws. I think they should be banned from guitars. Someone who is screw knowledgeably should start selling hex headed replacement screw packs so all the Phillips
headed screws on different guitars can easily be replaced.
Hex headed screws are easier to adjust precisely, the "screwdriver" doesn't slip and mar the finish of the guitar and worst of all the head doesn't get damaged so that an old screw can't be removed! Even if you don't want to go the full "add screw inserts" so you can't strip the wood because you remove and replace certain parts, hex headed screws are just smarter and easier.
I was adjusting a guitars intonation and had to find a long neck screw driver to adjust the screws and of course when the saddle needed to be moved, after loosening the strings, it still was difficult with the Phillips headed screwdriver. while it would have been so easy and precise with a hex headed screw. So someone please start selling hex headed replacement screw sets for every guitar and then outlaw the use of Phillips headed screws on guitar production FOREVER. Thanks
