Cagey said:What's the difference between a Fender neck joint and a Warmoth neck joint? As close as I can tell with some pretty expensive gauges, they're exactly the same thing, although the Warmoths are more consistent. But, I'm only measuring length, width, depth and floor angle. Time doesn't apply, but maybe there's a sixth dimension I should know about?
AGWAN said:I hope Cagey was asking you that... because I also made it rather obvious (though implied) that I know fender and Warmoth neck joints are the same.
Street Avenger said:AGWAN said:I hope Cagey was asking you that... because I also made it rather obvious (though implied) that I know fender and Warmoth neck joints are the same.
'Not sure what you mean by "the same". Warmoth's contoured heel is completely different from Fender's Deluxe contoured heel. Maybe we're not talking about the same thing though. When you say "AANJ", I assume you're referring to a contoured heel (although we all know that banez contours the back of their necks to blend into their rounded contoured heel, which might be what you were referring to).
