Tonar8352
Can you use a dye after the filler is applied??
Yes you can use dye after you fill the grain. But it will wind up looking like this Tele. If you look real close you can see the light colored filler on the edge of the dark soft grain since the dye did not stain the filler very good. The better route to go is to do it like Jack’s blue base. If you look at his graining all of the soft grain has the darker filler and it shows better. I learned the hard way with this Tele, I never was happy with it so I’m redoing it in Copper Powder.
Do it this way.
1. Stain
2. Wash coat of finish.
3. Tint your filler to the color you desire the grain to show.
4. Shoot a couple coats and level sand.
5. Shoot your burst color if you are bursting at this point.
6. Finish coats to wet sand and rub out.
