OK here's whats up, I'm on the last stages of my build (lanocaster) and do not know which bridge to use..
here is the story. the body has a flat neck pocket like a telecaster IE no tilt back the body will have a bigsby, the bigsby will be mounted where the body slopes away from level on the top (see Pict's) I mocked up the set up and the space from the top to the top of the bridge is only 1/2". I have two bridges in mind both are 14 radius first a fender mustang style bridge, should sit lower than a tom, or a locking roller (may need to rout a hole for it to sit in)
look at the photos and let me know what you think.
I'm more concerned with clearence than style.. the roller will sit higher the mustang lower
thanks
thanks
