HELP! Fretboard lifting from neck
phred
I have a Warmoth pro neck and the fretboard is lifting from the neck at the heel about 3/4 of an inch toward the headstock. I'll get some pics posted as soon as Yahoo lets me. Any clues on how to fix this? It is causing some choking out on bends around the 19th and 20th fret. I was going to remove the neck. Make sure the neck is perfectly straight then put some #10 super glue in the seam and let it soak in. Any other suggestions would be great.
Scott
I had the same thing happen to me. call them and try to send it back before you do anything else. They replaced mine.
No binding. It was sold with no finish, but I sprayed it with Deft semi gloss when I got it. I'll give them a call.
Scott
I sent my neck to Warmoth after talking with a rep there. They said it was out of warranty, but kindly fixed it for free and mailed it out the same day.  :hello2:
Thats cool.
Scott
