Gotoh 510T FE1 tremolo routing
If that is an Am Standard retrofit (which the Wilkinson is), I'd say the Wilkinson route.  IIRC, the Standard Strat (MIM) is a 6 hole trem.  The American Standard is the 2 point.  Why they would have 2 similar model names on similar, but non-identical, models is beyond me.
Scuffcakes said:
Look at the dimensions provided on the page you linked to then look here.  That should get your answer.
Thanks man but ... too easy! :-)
I've seen this link before writing.
My problem is simple: I haven't bought Gotoh 510T FE-1 so...
@ Super Turbo Deluxe Custom: ok my english is really poor, but I understood only a part of your message.
(IIRC... it's an acronym?)
As usual...
:sad: :sad: :sad: :sad: :sad: :sad:
Klark said:
If you want to use a 510 series trem with the recommended 'Wilkinson' rout, you will be left with this..
My new preference is to use the 'American Standard Fender' rout and just mod it a little with a dremel tool to accommodate the arm holder thingy.
