ihavenothingprofoundtosay
Yesterday, got a small pile of stuff for my upcoming headless project:
- Labella Tapewounds (5 string set), strap buttons, neck plate, and Gotoh-style tuners all from Carvin
- J-bass routing template & Stellar Tonestyler from Best Bass gear
- High C tapewound from JustStrings
The tuning will be D-G-C-F-Bb, I just haven't decided whether I'll be using the low B set tuned up, or High C tuned down. I'll have the strings for both, though, and the left over string will help determine what my next bass build will be. :glasses10:
Still waiting on:
- 5 string bass bridge (except I got it from Amazon for free w/points - yay Amex!)
- Warmoth Deluxe 5 straight paddle, all purpleheart, fretless w/o lines, black side dots, 1 7/8" nut. :toothy12: . . .ordered only 2 weeks ago.
See below. :toothy10:
Already on hand:
- Carvin J99 single coil (will be putting it in the sweetspot)
- mute switch (bass will be wired: pickup -> Tonestyler -> mute switch -> jack)
- a wonderful slab of purpleheart (pix attached)
The purpleheart slab I've had for a few months, and only recently decided to go with a travel sized bass. It's 6.75" x 36.25" x 1", and I'll be cutting it in half in the middle, planing it a bit, and folding it over; so I'll end up with a body 6.75" wide x 18" long x 1 7/8" thick, with a handful of chambers cut out right in the middle, and a ton of contouring.
For the wood, there's a ton of saw rash on one side of it, but that will be the side that will be routed out for the chamber & glued to the middle. The outer side will also need quite a bit of sanding, but not nearly so much to get it smooth. It's GORGEOUS - but I've yet to see a piece of purpleheart that wasn't.
The shape/layout will be somewhere between the Kramer Duke/Hondo Alien (and the tuners will be at the butt end) and the Steinberger Synapse. I don't know how exactly I would do it yet, but I like the idea of the little extension hook thing that the Synapse has for balancing the strap. I have a pencil sketch, but I'm too lazy to get it scanned on my wife's computer.
Oh, and since it's going to be both purple and magical, I'm pretty much required to call it The Alicorn. :headbang1: (see here for more info - IF YOU DARE!)
... and now I've still got weeks of waiting to go for the neck.
:sad1:
Already on hand:
