Hi there,
Anyone that has encounter problem with the Gecko neck/angled headstock? I'm planning to build a Gecko 5 but my concern is the angled headstock. I have a custom j-bass with warmoth neck and a Fender AMD 5string. Both basses has fell on their sides, luckily while in their cases. No problem has occured, so the fender "straight" headstock is strong.
I play mostly on small stages and there is always a risk that something happens to the instruments. 5piece band means lots of hands, feets and stuff. While my bandmates and I take very good care of our and each others instuments something always happens. 3/4 times my basses has fallen, has been due to my bandmates mistakes, feet, amp or drum has puffed to my case and the bass has fallen to it's side. Such things just happen and usually when carrying the stuff back or to the stages.
So the questions are:
1. Is the angled headstock weaker than a strait headstock?
2. Does Warmoth Gecko necks support the "superbass" construcktion
3. Is the 4-bolt neckjoint enough stable to support the tension from a 35" 5-string scale?
Cheers, Rolle
Cheers, Rolle
