S
		swarfrat
I have some gaps which weren't nearly as noticeable until I stained the sides of my guitar black. I tried filling them with wood filler, but they're shallow and it didn't really stick well. When I sanded most of the putty pulled out. I'm bursting the edges black to hide this, but I need to build it up to the same level as the surface. (It's lam top glued onto a base. I originally built it as one piece, then router planed the top 1/4" off, and glued another top in its place.  The gap is where I didn't QUITE go deep enough and picked up a previously imperceptible bit of the old roundover.)
The sides are black but the top is dye + clear. It is currently stained, hoping I'd get some bridging but alas no. So the stain on it now is probably presenting some adhesion difficulties. Whats my best option? (You can see a bit of the edge on the inside of the horn in the shot with the bridges, and on the butt top side in the other one.)
Also - the finish is shellac. Since the body is so small - I don't have a lot of room for a wide sweeping burst. But I still need to make a nice transition from black edges to clear. I figured that the template I used to route it plus an inch or two of spacing above might make a good mask for spraying the edge transition. But since the current finish is shellac - I'm not sure what I find in a rattle can that will go down on it.
