Strat Avenger
Cagey said:Street Avenger said:jay4321 said:Does zilch to the sound, I've put padding in a couple Floyd guitars (going way back to my 2nd guitar). You might be able to detect it in a lab. If anyone thinks their ears are that good hit me up. I work out of AC would give ridiculous action on a wager to see it.
P.S. - Cut up a padded mousepad. The $4 variety at Staples (black) are perfect.
It acts as a sound deadener. much like the same concept of lining a car's floorboards with sound deadening matting. Whether or not the effect is significant is debatable, but there would be no other reason for the more expensive guitars to "not" use it. I had a couple of ESP LTDs that had the stuff, then I got a more expensive Standard ESP, and it did not have it. 'Same with Ibanez. The more expensive Japanese models did not have it, yet the cheaper Korean ones did. It's a known fact that thick paint/finish deadens a guitar's sustain. So why would foam rubber lining be any different?...
A Floyd that isn't floating is a sinful waste, so one would deserve whatever one got for trying to make any other setup work. Given that, some black padding in the clearance route isn't going to affect anything, since the energy transfer takes place through the mounting posts anyway.
As for finish thickness affecting tone, that's an urban legend with absolutely no basis in fact, at least as far as electric guitars go. Acoustics are a different story. Finish makes a lot of difference on those, which is probably where the myth started.
I disagree on two accounts.
1: I disagree that a non-floating Floyd is a waste. In fact, none of them floated when it was first introduced. I think Steve Vai came up with the concept of routing out the body to do radical pull-ups. EVH has never used a floating Floyd, and he gets some pretty radical effects from his.
2: While I agree that finish type does not affect tone or sustain, it's a pretty well-known fact that a thick finish serves to dampen vibration.
As for the original topic, my Ibanez (cheaper Korean model) has the foam, and it sounds good, so I agree that it's probably not really an issue, however it was an observation on my part that the more expensive guitars omit that feature, and I assume there must be a reason for it. I bring this stuff up for the sake of discussion, and not to be argumentative...
