johnnyj
Hi folks,
i am thinking about ordering a new build in which i would like to try out the Floyd NFT. Unfortunately, I read a some bad things about the NFT and would be very glad to hear some first hand experiences from you before taking a wrong decision. I have these questions in my mind i couldnt find so far answered:
1. Is the floyd nft only usable with the wood screw in bolts or is it also compatible with the normal floyd studs? additional question: did you use both bolt systems and noticed a tonal difference?
2. when ordering from wartmoth the off menu nft recess option, do they also insert the studs for me even if i cannot buy the tremolo from them (not listed in their page)?
3. regarding the knife edges: did you experience edges wearing out at the nft? any other quality issues at the nft that you encountered?
4. is the nft coming with a 37mm block by standard? this is unfortunaltey not listed in the specs.
5. i read that the final guthrie version is different from what we can buy as floyd nft. can anybody tell me what is different?
6. can you give me some insights about the mechanic of the arm-baseplate connection? is it a nut with some plastic around the arm endpoint in the screw or is it metal on metal? screw at bottom and screw at the side for adjustment? are there any noises when moving the arm or is the arm perfectly fluid also after some playing months? except the gotoh and wilkinson by gotoh i found so many trems have this as a weak point, so i am wondering if the nft is a step back here?
7. did you experience any tuning issues with the unit where you isolated the issue to be somewhere in the tremolo (e.g. having perfect saddle, lock tuners etc.)?
8. i would like to have a very flat shredding neck with 12-16 or maybe 15 or 16 straight radius, will the nft be compatible?
9. regarding a fallback option: in case i dont like the nft, will i be able to swap it for the schaller vintage? i had this unit before and found it good (except of the arm nut). it seems that the major difference in the spacings is the stud spacing of 74 (nft) vs 74,3 (schaller). do the 0,3mm matter and ruin the stability? did anybody of you fitted both tremolos in one guitar without changing studs? and did anybody who went for the recess nft route use this route for the schaller vintage so far?
10. what is your overall satisfaction with the nft?
sorry for this big wall of text, but all inputs on these questions would really help me out.
best
johnny
best
johnny
