Gojaco
Hello fellow guitar enjoyers,
a few days ago I asked about drilling holes with pot sizes and I have explored further options that make me have to drill less holes in weird places. This made me run into another idea. THE RHYTHM CIRCUIT! Why didn't I think of that earlier? lol
Anyway this helps me solve the issue of having too little space for knobs or having to put them in strange places. However it comes with some additional challenges. For anybody who isn't up to the lore:
I'm putting together a Jazzmaster and there are some things I want to do but I am pretty inexperienced with actually making my own wiring schematics. Right now I have the following parts I want to put in the circuit and limitations due to parts I already have/want to use or that fit:
- I want to use a passive humbucker (Seymour Duncan SH-5) in the bridge position and a P90 (Seymour Duncan Phat Cat) in the neck
- I want to use a 3-way switch to switch between the bridge pickup, both pickups combined and the neck pickup alone (normal stuff lol)
- The switch usually used to engage the rhythm circuit will be used by me as a coil split for the bridge position (It's an on-on switch)
- I want to use the roller knobs as seperate tone knobs for the bridge and neck position (as far as I know the fitting knobs are only available as 50k or 1meg pots)
- The volume pot is a 500k pot with a treble bleed mod
- The other hole for a knob will be fitted with a 6-way rotary switch to have a Varitone type circuit I bought off reverb. There is a wiring diagram that came with it but it's for a 2vol/2tone+varitone circuit guitar
A friend of mine will help me wire this up since he has wired up a lot more circuits but I want to make his work as easy as possible and make my own wiring schematic. He has installed some coil splits before so if worst comes to worse he would probably know how to do this but with everything going on I feel a lot more at ease having a wiring diagram prepared.
Now my questions are:
- How would I have to modify this circuit to account for having only 1 master volume knob and a coil split for the bridge pickup?
- Would it be a problem to have mismatched tone and volume knobs? If so does anybody know what 500k tone pots work for roller knobs? If it's not a problem using the 1meg-ohm pot is probably a better idea if I want to have a modern sounding guitar right?
Any help is appreciated
