fdesalvo said:OK I can't comment on the grain fill/sanding bit, however -
If you are finding glossy spots, you simply need to keep applying. Since you are going for a gloss finish, you need to keep going and keep the coats as thin as humanly possible.
Cagey said:That's moving along nicely. Starting to actually look like cordovan. I was wondering at first.
2ManyShoes said:Just a progress report. Took these pics dry this morning. I'm about 10 coats in on the cap and neck (8 in on the back because of grain-filling) and with the warmer weather (it was 80 here yesterday) I've moved to two coats a day, about 12 hours apart. Starting to get some thickness to the finish. It's a little orange-peely in places, from some angles. I'm hoping the final sanding and polishing will smooth it out completely.
I thought it would be fun to use up some maroon-dyed tung oil I had left over from my last build by staining the pickup cavities. Of course, I got a thumbprint on the body while doing it, which I had to sand off.
2ManyShoes said:I have a Micromesh set, although this will be the first time I use it. I actually have a couple of questions about the final sanding/polishing phase.
1. Do you work with the grain, or in circles?
2. I plan on sanding wet. What is the best liquid to use? I've heard everything from soapy water to more Tru Oil.
2ManyShoes said:While I'm at it, I have three more questions.
1. How long do you let the body and neck cure before the final sanding/polishing?
2. After Micromesh, what sort of finishing compound do you all recommend? Preferably something generally available at woodworking stores, so I won't have to send off to StewMac and pay their @#*%ing shipping fees.
3. Do you recommend wax (carnauba) as a final step, assuming that the finish is thick enough that there won't be touch-ups down the road?
