I'm embarking on my first attempt at building my own guitar. I'm going for a Tele neck (Gonçalo Alves/Ebony) and Tele body. However, I can't choose between 2 different directions I want to take my Tele in.
1) Standard Tele, but with a 4 way switch mod.
2) Esquire with a humbucker wired to the 3 way switch (series/split/parallel).
The idea with both options is to give me that fatter, thicker sound that is sometimes missing in single coil guitars (the 4th position on the Tele, or the humbucker on the Esquire). The difference is that with option 1, it'll still sound like a Tele, but with option 2 it'll be a different kind of animal. Probably more Les Paul, since I'm looking at th SD Little 59. That's appealing because I already have a Strat (SSS) but I don't have any humbucking guitars. On the other hand, I've never had a Tele, and I've always wanted one, so that draws me to the first option.
The humbucking Esquire is a bit more different than the standard Tele with the 4 way switch. I'm thinking because it's a custom guitar, different/unusual is better. After all, I can buy a Tele with a 4 way switch (like the Baja) from Fender. My only concern with the Esquire is that it'll be a one trick pony. Even with the 3 way switch, I think it might end up being good for high gain but naught much else.
Any thoughts?
Any thoughts?
