Axkoa
I'm 2 months into my Engineering degree at University and I'm already craving doing some DIY projects. The perfect opportunity came to me, my University opened up a workshop on campus for Engineering students that lets us go in and work on anything that we want, no need for proper justification. This workshop has soldering irons, wire, 3D printers, multi-meters, a laser cutter, and tons more stuff including consumables. I feel super lucky being able to access this for essentially free!
My idea for this is pretty simple, eventually I want to make a system that you are able to change the order of the pedals on a pedalboard without having to unplug them, as well as being able to take the pedals off of the pedalboard without having to unplug the input, output, and power jacks from the pedal. I would like to one day have this on a small LCD touchscreen, something like the Line 6 Helix, but I'll wait to do that for when I actually understand more about electronics than I do now, further on into my degree.
Firstly, I did a bit of research on some stuff. I started to understand more about how connectors work. I had originally designed both my base and the part that will Velcro onto the bottom of the pedal using a 9 Way D Sub connector, but after some help by a couple of you I decided to change that to an XLR jack for my input and output signals and a simple 2.1 mm DC Barrel Jack for my DC power.
Day 1 - Friday 07/04/2017:
Woke up early to head into University to start sorting out 3D printing out a prototype chassis for the design. I had completed the design the night before.
One thing you can't really see is how small the design is. Though they aren't scaled at the right sizes in that pictures (thanks paint.net), the real size for the big hole in the top left is actually 22 mm! Which is just too small to chassis mount an XLR Female Socket. The hole for the XLR Male Jack in the bottom right design is just the right size.
I got into University and with some time messing around trying to 3D and fixing up the designs for mainly the tabs I were going to the top and bottom parts together with, I finally managed to start 3D print it. I haven't really got many in progress shots but I have just one that my mate took for me whilst I wasn't there.
Whilst this was printing I decided to try my hand at some soldering, luckily I had my friend to help me out with holding stuff I wouldn't have been able to do this AT ALL. It seems like you need an extra 2 hands to solder...Firstly I soldered the two 1/4" jacks that I would be using the connect to the XLR in the top part of the design, the one that would connect to the bottom of the pedal. Probably if I did this again I would by some better cabling, the cabling works (I tried it the instant I got home) but it would be nicer to get something a little sturdier, though I'm not entirely sure. Thoughts? Both sides of this cable have 1/4" jacks on it but I'm going to cut it into quarters so I get 2 individual jacks that I can connect straight to the XLR jack.
While it was STILL 3D printing I also soldered together the power jack that would connect from the power jack in the top part of the unit to the power in the pedal. This was pretty easy to do and I ended up putting some heatshrink on it because; why not? Pretty happy with how my soldering turned out on this and I'm fairly certain it works fine, well the multi-meter told me it worked...
So after 5 FREAKIN' hours of printing it finally finished, 20 minutes before the workshop closed. So in that 20 minutes me and my mate got a couple files to it and made the corners less dodgy as well as cleaning out the holes a bit. On the bus trip home I also mounted the parts that I could, the two mono sockets I have in the base as well as the two 2.1 mm DC Power Sockets in the base part. But here are all the 3D printed parts!
I learnt a lot throughout the day...mainly not to get your hand too close to the solder incase it spits at you. But overall it was a pretty fun Friday I had.
On Saturday I decided to change my design, and instead of 3D printing it I was going to laser cut it out of plywood. Now a list of some things I've also changed...starting from the base to the top unit.
Here are the new designs for the laser cutting.
So that's my first overall update! I hope you enjoyed reading it (if you read it all :icon_thumright. I would be incredibly grateful if any of you that has some more knowledge about this kind of stuff could give me some hints.
Thanks!
Cameron
- Spread out the mono sockets more, I tested out later and I couldn't fit the two pancake jacks into the sockets as well as a right angle power jack. Spreading this out as well as bringing the power jack higher should help it.
- Changed the overall height of the base from 34 mm to 45 mm. This coincides with my decision to have the chassis mounted XLR Female Socket on the base instead of the top. I have no idea why I had it that way in the first place...but I've fixed it.
- Designed the whole base and top units with tabs that mean that it would be able to be glued together, hopefully this should look a lot better as well as work better.
- With the top unit now, made the hole smaller for the XLR port so instead of the Female it's the Male.
- Instead of having a singular hole for all of the cables to come out of the top unit, I have 3 different holes, one for each type of cable that comes out.
- Changed the height of the base from 20 mm to 45 mm as well...So I can properly mount the Male XLR Jack.
- Changed the design from a irregular hexagon (?) to just a rectangle. Did this so I can actually properly laser cut it.
Thanks!
Cameron
