Tony Ounsworth
Morning all.
I had a Squier Strat knocking around which cost me £40. It was ok, I'd already upgraded it quite a bit, but the sunburst finish was very "boiled sweet" and the joins in the body wood were very unsubtle (especially under the jack plate). No interesting wood grain visible, just a pretty cheap finish, as you might expect.
So I decided to have a crack at sanding and re-spraying the body, using acrylic car paint and acrylic clear gloss lacquer. I haven't got a garage or anything like that, but I do have a small outside cupboard which I rigged up as follows:
The bungee cords are quite handy, as I can easily spin the body. Anyway, long story short the grey primer went on fine, and then I moved on to the metallic colour coat (Aquamarine Frost, a blue/green Ford colour). This I did with the body flat in a large plastic box, as I understand the flakes need to "flop" in different directions to reflect the light and give the metallic effect you're after.
This also went well, although I was learning from my mistakes along the way. Had to stop and sand various runs, remove dust etc, but in the end I was actually pretty stoked with the results.
This is the guitar mocked up with no clear coating yet applied:
What happened next was I went backwards! I applied a few coats of clear acrylic lacquer, then like an idiot tried to flick a hair off the body. Of course it made a mess. Tried to remove the mess. Made a bigger mess. Left fingerprints. Argh!
So I wasted a whole weekend waiting for it to dry, then wet sanding the mistakes out, then re-spraying the sand-throughs, until finally on Sunday I was ready to re-start the clear coating.
Which brings me to my questions:
1) I've done about 6 coats of clear acrylic lacquer now. How many in total should I apply? I haven't touched the body at all other than to wipe it down with a tack cloth each day before putting new coats on
2) The can says to let the clear coat harden for two weeks. How accurate is this?
3) Most importantly, any tips for sanding/polishing the coat to a high gloss finish? I was planning on starting at 1,200 grit, then up to a 3,000 grit polishing cloth, but I also have some rubbing compound. What's a good plan for doing this?
It's a fairly low-risk endeavour, so it doesn't matter if I mess it up, but it's going well so far and I'd like that to continue!
