Hi All,
First post, first build.
I ordered the neck and body what seems like a century ago, and still another 4 or 5 weeks till they come, sigh!! Basic spec's are Mooncaster body - quilted maple with Bengal burst, wenge neck and ebony fretboard.
I'm planning all black hardware, and probably being a bit ocd about it, i've swapped out the chrome screws that came with the SD pups and blued the polepiece screws.
See pics. below for some prep. work i've done - hope I'm not being too ambitious, time will tell.
The first photo is a headstock veneer / inlay, unfinished but ready to apply.
Second is pup rings, can't do any more work on those until I get the guitar and cut the correct base contours, thickness and final outside shape. As you can see i'm using p rails and set triple shot switches into the wood.
Third is the vol & tone knobs and 3 pos. switch pre wired. Not convinced about these, will wait and see.
Last is the Schaller locking tuners, i've changed the knobs to ebony and inlaid the MOP.
Not a lot of info. out there about Mooncasters, would anyone know the answer to these:
Should I get long or short shaft pots (how thick is the front panel)?
Is the rear rout deep enough for push / pulls?
I've read of problems getting the switch into the cavity in the lower horn (I'm using a right angled Switchcraft one). Does anyone know if this is still the case?
Best regards and thanks in advance for any info. you may have. :help:
