Hey everyone, apologies for the long post. I'm hoping this is the best place for some feedback and suggestions on hardware compatibility and what to order in general. I'm going to post the specs of my neck and body and then list what I currently have in my cart accompanied by a few questions. I want to make sure I get everything I need in one order to avoid additional shipping fees! I think I did my due diligence by following Warmoth's compatibility pages to the best of my ability, but I have no one to double check my decisions. I understand if I come off as uninformed and some questions may be stupid. For that I apologize but I greatly appreciate if someone decides to read through and help out. I'm going to attach pictures of my neck and body for reference.
I'll start with my neck:
Style: Stratocaster®
Construction: Modern Construction
Orientation: Right Handed
Neck Wood: Maple
Fingerboard Wood: Pau Ferro
Nut Width: 1-11/16"
Back Shape: Standard thin
Fret Size: SS6230 (Stainless)
Tuner Ream: Vintage Style (11/32")
Radius: 10-16" Compound
Scale: 25-1/2"
Fret #: 22
Pre-Cut Installed String Nut: GraphTech Black TUSQ XL - Standard Nut
Inlays: Cream Face Dots
Side Dots: White Side Dots
Finish: No Finish
Tuners:
https://www.warmoth.com/-P965.aspx
Neck plate and screws:
https://www.warmoth.com/-P832.aspx
https://www.warmoth.com/-P142.aspx
I figure most of what I'm missing is in the wiring and body hardware. I didn't see anything else required for the neck.
Body specs:
Model: Stratocaster®
Orientation: Right handed
F-Holes: None
Scale: 25-1/2"
Wood: Alder
Rout: Top Rout
Pickup Rout: Strat®, Strat®, Strat®
Controls: None
Bridge: Vintage Strat® Flat Mount
Jack Rout: Strat® Top Jack Rout
Neck Pocket: Strat® Shape
Contours: / Tummy Cut / Forearm Contour
Battery Box: No Battery Box Rout
Bridge:
https://www.warmoth.com/-P580.aspx
My main question here is if this will fit properly. I have a notch that came on my body that I can't quite understand from pictures what its purpose is - circled in one of the attached pictures.
Bridge Pickup:
https://www.warmoth.com/-P1089.aspx
Middle Pickup:
https://www.warmoth.com/-P1819.aspx
Neck Pickup:
https://www.warmoth.com/-P1820.aspx
I'm hoping these fit even though they don't exactly match the cut outs. They were options in the custom build designer.
Switch and Screws:
https://www.warmoth.com/-P722.aspx
https://www.warmoth.com/-P148.aspx
Strap holders:
https://www.warmoth.com/-P79.aspx
Switch knob:
https://www.warmoth.com/-P390.aspx
Jack Cover:
https://www.warmoth.com/-P835.aspx
Volume Knobs:
https://www.warmoth.com/-P369.aspx x3
Pick Guard:
Shape - Stratocaster®
Color - .06" Black Solid Matte
Standard Bridge Cut
Mounting Holes - 11 Hole
Standard Countersink
Neck Pickup - Strat®
Middle Pickup - Strat®
Bridge Pickup - Strat®
Control Routing:
Volume
Tone
Tone 2
5 Way Switch
So I know I need some more equipment to make the wiring work such as a jack and pots and probably something else (wire?) But I'm not sure which ones to choose. I'm also guessing I've left some stuff out by forgetting or not understanding. If anyone decides to help me out I'll promise to send you pictures of the completed product. Not much of a reward, I know
Neck Wood: Maple
Nut Width: 1-11/16"
Scale: 25-1/2"
Fret #: 22
Finish: No Finish
Tuners:
Body specs:
F-Holes: None
Scale: 25-1/2"
Wood: Alder
Rout: Top Rout
Controls: None
Bridge:
Bridge Pickup:
Middle Pickup:
Neck Pickup:
Switch and Screws:
Strap holders:
Switch knob:
Jack Cover:
Volume Knobs:
Pick Guard:
Standard Bridge Cut
Control Routing:
Volume
Tone
Tone 2
5 Way Switch
