Firecaster III aka Inferno Flake Jazzmaster
Rick
Epic Member
First let me thank everyone who helped in the journey to make this guitar, especially all the helpful suggestions from the folks on Unofficial Warmoth, and all the people that made the top notch parts that went into this instrument. It was a fun build.
firecaster-neck-plate-jpg.63390
firecaster-left-jpg.63388
firecaster-split-switch-jpg.63393
firecaster-top-side-jpg.63396
firecaster-case-jpg.64439
Total weight: 8 Lbs. 2oz
Warhead Guitar Neck
Construction Modern
Shaft Wood Quartersawn Maple
Fretboard Wood Indian Rosewood
Nut Width 1-3/4" (44mm) - Wide
Right / Left Handed Right-Handed
Neck Back Profile Wolfgang
Fretboard Radius 10" - 16" Compound
Number of Frets 21
Scallops None
Binding None
Fret Size & Material SS6150 - Wide & Tall (Stainless)
Tuner Hole Size Schaller/Modern Fender/Sperzel (25/64")
Inlay Shape Split Diamond
Inlay Material White Pearloid
Side Dots White Side Dots
String Nut Standard Nut - GraphTech White TUSQ XL
Mounting Holes Standard 4-Bolt
Neck Heel Shape Strat® Shape
Finish Vintage Tint Gloss
Jazzmaster® Replacement Guitar Body
Construction
Chambered
Core Wood **Extra Light Poplar**
Lam Top Wood Alder
Control Cavity Top Rout
Neck Pickup Rout Humbucker
Middle Pickup Rout Humbucker
Bridge Pickup Rout Humbucker
F-Holes None
Jack Rout 7/8" (22mm) Side Jack Hole
Bridge Rout Type Hardtail
Bridge Rout Fender American Standard Strat® Flat Mount
Neck Pocket Shape Strat®
Body Contours Forearm Contour, Tummy Cut
Binding and Edge Decorations Pearloid Binding (Drop Top)
Battery Box None
Paint Category Flake
Inferno Flake
Gloss
Jazzmaster® Pickguard
Color / Material White Pearl
Right / Left Orientation Right-Handed
Neck Pickup Rout **Gibson Mini Hum**
Middle Pickup **Gibson Mini Hum**
Bridge Pickup **Gibson Mini Hum**
Bridge Cut Non-Jazzmaster® Tremolo or Hardtail Bridge
Controls Volume 1, Tone 1, Input Jack
Upper Switch Upper Blade Switch
Lower Switch None
Hardware and electronics from Warmoth
Neck Screws Color Stainless-Steel
Pickguard Screws Color Stainless-Steel
1/4" Jack, Mono
Football Side-Jack Plate Color Chrome
Flat-Top Knob Color Chrome x2
500K Audio Pot x2
Guitar String Ferrule x6 Color Chrome
Schaller S-Locks Color Chrome
Non-Warmoth Parts
Tuners: Hipshot Staggered Locking Tuners with UMP plate chrome
Buttons: Hipshot Hex Pearloid
Bridge: Callaham Am. Std Hardtail w/ 3 enhanced compensated brass saddles
Custom Neck Plate with pad from calfabric
PUPS: DiMarzio Minihumbuckers DP 240x2 + DP241
tone control: .022 mfd cap
Treble Bleed on volume: 180pf
Blade switch: Freeway 10 position (20 options) 5B5-01
Miniswitch On/on 3dpt
Dress nut for miniswitch
Miniswitch tip: white
Case: Gator Jazzmaster. Modified with extra padding.
Strap: Sun Strap Red
Stings: D'Addario Nickel 10's
Build Thread
I think what kicked it up a notch was the pearloid binding. I was wondering if there would be too much bling, given the flake, but, thanks to the folks here with their great advice, I got over my apprehension and am really happy. I smile when I pull this thing out.
I would've thought the same as you and wouldn't have done the pearloid binding thinking it would be too much but, dang, that looks amazing. :love:
View attachment 63762View attachment 63763View attachment 63765
Warhead Guitar Neck
Construction Modern
Number of Frets 21
Scallops None
Binding None
Construction
Chambered
Lam Top Wood Alder
F-Holes None
Battery Box None
Inferno Flake
Gloss
Lower Switch None
1/4" Jack, Mono
500K Audio Pot x2
Non-Warmoth Parts
Toggle: Freeway 10 position
Build Thread
Your welcome you smelly man!
