Fender tremolo installation question
WarmothRules
Those two screws under the body that hold the piece that holds the springs. How do you go about drilling the holes for that what size drill bit? How long?
If you're using a Warmoth body, the pilot holes are already drilled.
If not, you need to use a longish bit at least one size smaller than the screws you are going to use to drill the pilot holes, mark the spots for the screws using the spring claw centered in the trem cavity then drill in at about a 15 degree angle to depth.
Oh warmoth bodies have them drilled? awesome. I didn't order the body yet but thats real good to know they are allready drilled
