J
jmavl
Quilt maple laminate top & back. Maple sides & neck.
Used wine colored rit dye in denatured alcohol on top & back to accent the wood figuring. Applied, dried & sanded back three times. Used minwax mahogony oil based dye on the sides & neck. Applied and sanded back twice. Applied boiled linseed oil until the wood stopped absorbing-- two liberal coats. Using Tru-oil for the top coat. Applied three light coats, wet sanded with 1500. Applied a fourth coat, and the gloss is beginning to appear. Will apply two more coats, and again wet sand with 1500. Then two more coats and final polishing.
