Easiest kind of finish for DIY?
I sort of went down this same road from friends and family asking what can you do or help me do requests wanting to put together a custom guitar that looks good but not "like furniture" or "homemade". I think its a catch-22. Most of the the classic finishes were colorful solid or translucent high gloss made with industrial equipment. There's no kitchen table shortcut to that. If there were people couldn't charge hundreds of dollars for it.
Here is what I came up with for unofficial students in Mr. Burst's unofficial newbie finishing course with some flexibility :
Get an alder, basswood, or poplar body. You're not pore filling mahogany or ash on your first build :)
1. aerosol white or gray primer
2. solid color of choice - metallics are discouraged because they're unforgiving of common newbie issues like runs from spraying to heavy
3. satin - you're not buffing on your first finish either :cool:
Between coats scuff sand and only worry about removing horrible runs with 400g. Satin isn't meant to be buffed and cosmetically its more tolerant of rough spots since its less reflective. My reason being if someone has no experience, sanding through is the major gotcha. Aerosol coats are notoriously thin low solids. Sand through your sea foam green and you will be cursing its a pain to repair.
This doesn't even get into other factors which can make or break the quality. Do they actually have somewhere to spray that is properly lit, shielded from elements, are they able to make some kind of holder/hanger, small sanding block, and so on.
Stew-Mac is the only active aerosol maker I've used but color choice is limited and they are always top of market pricing. Newer players like Gracey's, Oxford, Ohio Valley, and Great Lakes look promising but I haven't tried. Not everyone offers every color so it's best to find the color you want and order a bundle from one supplier. Nowadays they all provide pretty solid step by step procedures to guide you.
I haven’t used them, but the Wudtone finishing kits seems pretty nice.
Since this thread has come back up again....
I went with @Hodgo suggestion of Wudtone. I bought their "Flamenco Cherry" kit and finished the Bass Body of Tonal Discovery with it. Video is scheduled to air July 10th.
In the video I called it "wipe-on poly" a couple times, but I'm not sure that's the case. Oh well. History has shown me that if I misspeak in a video the citizens of YouTube will treat me with kindness and gently correct me.
And the denizens of the Internet will also provide helpful alternatives with rationales if they disagree with a suggestion as well as striving to understand your position first.
I don’t believe it is, they don’t exactly advertise it but from what I’ve read it acts more like a pigmented TruOil type thing? Excited to see how you got on with it.
They are a little coy about what exactly it is on the website, but I'm sure I'll be told soon enough. LOL.
With the spray cans (eg Rustoleum or Duplicolor), is ordering the body with the DIY ready option completely out of the question? Your options are either do that or get ready to sand. In my opinion spending $125 is worth not having to sand anything myself. If that’s too much, maybe cook at home for a week instead of getting takeout to compensate.
From there it would just be 2 coats of primer, 3 coats of paint, 2 coats of finish.
Actually I made a bit of a mistake here. You’re still going to need to sand.
You should still be sanding the primer with 320 grit between each coat, and before you spray the color. Whether or not you sand the color with 600 grit prior to applying the clear coat is a point of contention, and depends on how evenly you sprayed it, how much running and dripping you caused, and how glossy or satin your clear coat will be.
Wet sanding with 1000 grit and polishing the clear coat is another point of contention I have no personal experience with.
Which leads me to the question, if you order the DIY finish option instead of bare wood, do you just start with the primer? Is it suggested you use grain filler or anything first? DIY definitely saves a lot of effort for the customer but might not be totally worth it if you’re comfortable with sanding.
I dye mine with Angelus leather dyes and finish with tru-oil. Easy and fun, you can't really screw it up too bad.
I buy unfinished bodies cause I'm trying to save money (as Aaron said) and even still, this is an expensive hobby. That said, I wouldn't even attempt to do a DIY paint job, I think what Warmoth charges is perfectly reasonable for the time and effort (not to mention expertise) involved.
Simple, easy, Osmo Polyx-Oil gets my vote. Wipe on the raw wood with a rag, wait 15 minutes to soak in, wipe off all excess. Let dry, repeat with a second coat the next day. Let dry. DONE!
Nice translucent slightly amber natural finish. They suggest 100% cure in a week or two, but two coats in two days is already an amazing finish, not even the slightest bit tacky. Perfect natural finish for swamp ash! (https://unofficialwarmoth.com/threads/z4-short-scale.40451/post-514761)
I misread the instructions and went for a third coat on my alder tele, but WRONG... It only needs two coats!! That had no absorption left, and after assiduous wipe down, it took a few days to finally dry . Next project, I will stop at TWO ...
