sundin4prez
does anybody know how to build there own pedals............i have been searching for a while , but i cant find kits of any sort.................so....
-CB- said:thats the place
I built up a bluesbreaker box clone... then bought a bluesbreaker to see how it sounded compared to the original.
they were virtually identical - could not tell em apart
I ended up modding the clone a bit, then since Vic got the original, I modded his the same way
ildar said:-CB- said:thats the place
That's the beauty of diy'ing fx pedals from the ground up-you can build in ease of modifications, rather than a kit, in which you kind of have to stick to the formula. Unless you like soldering flying leads and daughter boards in a 3" by 2" box. :laughing8:
Really?Ted said:ildar said:-CB- said:thats the place
:doh:
You "stick to the formula" because thats how the original pedal was built!
If you want to mod certain elemets like bass, more gain etc, you can do this with a kit as easily as building from the ground up.
I'd recommend BYOC to anyone interested in learning more about pedals. I've built quite a few and often these require no mods as they sound so good.
ildar said:Really?Ted said:ildar said:-CB- said:thats the place
:doh:
Suppose you want the input stage from a Tube Screamer, tonestack from one of the Runoffgroove so-called "amp sim" circuits, and the output stage from a BMP? How about adding a comp circuit in there somewhere?
What I said was mods and customization is much easier when you go from the ground up. But go ahead, drop $70, $80, $100 on a clone circuit and I'll build pedals the way I want them for about $25 a piece.
+1!! Well said Patrick.Patrick from Davis said:I'd also make the point that not everyone wants to build something from the ground up. I guess I don't want to buy a guitar blank to cut the shape out, route the cavities, and finish the guitar body. The kit takes care of a lot of those details I do not want to deal with. You can still play with a ton of different modification without having to play with perfboard/stripboard. I agree with one of your earlier posts that most dirt boxes do not require much, but some pedals do. I would like a pedal I can kick around, and I have more confidence in a PCB on the more complex pedals.
That being said, I also have perf board and stripboard projects. Noisemakers that no one else saw fit to try... But for something like a chorus, I am buying a kit and modding it rather than building one from the ground up. My $0.02.
