justsomeguy1
https://warmoth.com/index.php/wilkinson-stud
Wondering if anyone knows the exact diameter of these studs/inserts. Unsure of proper term. The part that gets fitted into the body.
I know the website says to use 3/8" drill bit. Bought a different Wilkinson bridge that is supposed to be a drop in replacement for a Gotoh 510, which it is. But the angle of the area where the knife edge sits is greater on the studs that shipped with my new bridge, and hoping I can install them instead. Diameter is 9mm for the new inserts though so I'm thinking I'm out of luck.
