Hello, i just want to know if these pickups would work with regards string spacing?
I'm looking at attaching the Hipshot A style .687 (17.5mm) bridge that has a total string spacing of 70mm and I will be having a warmoth deluxe 5 neck with. 1 3/4 inch (44.45mm) nut width.
I would like to make sure that the strings would be right over the poles on these pickups. I plan on having a delano Music man/jazz pickup combo. I know the position will make a difference, so the neck jazz (neck) will be in the normal jazz position and the music man (bridge) will be around the normal jazz position.
Music man bridge - 17.55mm spacing
http://www.delano.de/products.html?&cHash=d202f54d0e&tx_smtdelano_pi1%5Bcat%5D=1&tx_smtdelano_pi1%5Bseries%5D=7&tx_smtdelano_pi1%5Bstrings%5D=6&tx_smtdelano_pi1%5Bsystem%5D=55
Jazz neck - 17mm spacing
http://www.delano.de/products.html?&cHash=2d35d5ab6f&tx_smtdelano_pi1%5Bcat%5D=1&tx_smtdelano_pi1%5Bseries%5D=5&tx_smtdelano_pi1%5Bstrings%5D=6&tx_smtdelano_pi1%5Bsystem%5D=39
I hope this makes sense, it does in my head...i think...So if anyone can shed some light on this that would be great. Or if you have a deluxe 5 with the same bridge and nut measurements, could you tell me your spacing at the standard jazz positions?
Many thanks
Many thanks
