spauldingrules
As you know, I have an Epi Valve Junior head which I really like. The input jack has become loose, and I need to stabilize the jack on the inside to tighten it. From looking online, people warn novices to NOT open the chassis due to shock hazard. How dangerous would it be to open the chassis (not just the back to access the area with the tubes) to hold onto the jack to tighten things? Is there an easy way to drain the power completely from the amp? The amp is 5 watts - I'm assuming it's still dangerous.
Any advice?
Thanks,
spaulding
Any advice?
Thanks,
spaulding
