OK, so the input jack on my BH little giant got scratchy a while ago, and contact cleaner wouldn't do the trick, so I replaced it with a switchcraft jack. Of course, now it doesn't work at all. So I did what any normal guy would do who has another amp he can play: I put the BH in the closet for a couple months. :icon_thumright: Dug it out last week while the wife was away, and it seems that the jack is properly soldered in, so I tested nearby components to see if I fried something in the process - one capacitor, C19 in the attached pic, has no continuity as far as I can tell. It is supposed to go from the input jack sleeve to ground, if I'm reading the schematic right.
If I had fried this component, would it cause me to get zero output from the amp - no sound whatsoever? The tubes light up and the fuses are fine.
The value is listed at .01 1kv - is that .01uf, 1 kilovolt? If so, I'm assuming I can head to radioshack and pick up another one.
If anyone has other suggestions I'm very open - I'm pretty clueless around amps. Yes the caps are self-draining and I don't intend to kill myself. :toothy11:
Thanks!
Thanks!
