WchoyCustomGuitars
Hey! Last Christmas, I was able to score a mahogany Switchback offset V body in the Screamin' Deals section of the Warmoth website. The body has the contoured heel option, where the heel attachment area of the body is kind of angled & sloped and not perpendicular to the neck pocket surface. I'm planning on ordering a Warmoth neck soon and had a (stupid?) question: Should I order a neck with standard 4 mounting holes already drilled, or the $15 option to have the neck holes undrilled (to be drilled myself after clamping the neck onto the body)? Are the contoured heel mounting holes 90 degree perpendicular to the neck pocket mounting surface? Are the body's drilled mounting holes slightly angled? I took a look at the holes on the body, and I'm not 100% certain that they are squared to the neck pocket surface plane. Thank you for your help - I appreciate it. Looking forward to the build.
