Confused???
jackthehack
Epic Member
How do you install/run the wires from the pickup switch to the controls? Looks like it's missing an access plate...
http://www.warmoth.com/Showcase/ShowcaseItem.aspx?Body=2&Type=92&Path=Mooncaster&i=MP547#.V99nPzMrLnB
It's hollow and that switch isn't too far from the control cavity. The couple of hollow bodies I've worked on didn't have any cavity covers. I rewired a Ghost setup on a Schecter C1 A/E and installed some ZW EMG's in an Epiphone Studio Dot. You basically go fishin through the f hole and the pickup cavities.
You do it the same way you would do with any other hollowbody. That is to say, it's a PITA, and you do it any way you can manage. One way is to tape a piece of string to the switch, and pull it through the hole.
That's a sharp body! Black binding around a clear vintage tint finish on swamp ash...mmmm
If it's full hollow, then when the cavity cover is off you should be able to see down to the horn where the switch hole is... :icon_thumright:
