After speaking with a rep at Warmoth who recommended I NOT use a drill press, I bought this at Sears tonight:
http://www.sears.com/shc/s/p_10153_12605_00940884000P
I was able to mod my vintage holes to 25/64 Schaller holes in an hour and a half. I went slowly and took great care to make sure the reamer was grinding the hole straight. What I did was grind it a bit, then pop in the tuner to check the fit and then repeat as needed.
Sears also had this which I found AFTER I had reamed the holes (doh!)
http://www.sears.com/shc/s/p_10153_12605_00999024000P
In hindsight the screwdriver handle might have made things easier. Yet, I can vouch for the first one that I did use that it works like a charm. Good luck.
