Yes. We are getting that ironed out right now. It requires the LP control cavity in the back for that control layout.rockskate4x said:can it come with les paul control holes?
I think what your asking is if this is like our DL lamtops in which we can laminate a thin veneer on top of an already carved body. That type of laminate cannot be done with this body so far. We do in fact use a standard 3/4" thick lamtop for the Carved Top Tele. We can only do the DL style laminate on the VIP body and an LP Carved Top body currently.elgravos said:If I understand it correctly the carved top in this case really just means that the top side of the main body blank is carved and we then have the option of putting a laminate on top of that? This is not the same as a 3/4" cap like we can get on an LP or a VIP?
Gregg said:I think what your asking is if this is like our DL lamtops in which we can laminate a thin veneer on top of an already carved body. That type of laminate cannot be done with this body so far. We do in fact use a standard 3/4" thick lamtop for the Carved Top Tele. We can only do the DL style laminate on the VIP body and an LP Carved Top body currently.elgravos said:If I understand it correctly the carved top in this case really just means that the top side of the main body blank is carved and we then have the option of putting a laminate on top of that? This is not the same as a 3/4" cap like we can get on an LP or a VIP?
Gregg said:... We do in fact use a standard 3/4" thick lamtop for the Carved Top Tele. We can only do the DL style laminate on the VIP body and an LP Carved Top body currently.
Unfortunately not on the Carved Top Tele.Unwound G said:Gregg said:I think what your asking is if this is like our DL lamtops in which we can laminate a thin veneer on top of an already carved body. That type of laminate cannot be done with this body so far. We do in fact use a standard 3/4" thick lamtop for the Carved Top Tele. We can only do the DL style laminate on the VIP body and an LP Carved Top body currently.elgravos said:If I understand it correctly the carved top in this case really just means that the top side of the main body blank is carved and we then have the option of putting a laminate on top of that? This is not the same as a 3/4" cap like we can get on an LP or a VIP?
Will it be possible to request for recessed control holes ?
Max said:Not sure how keen I am on the horn bevel, though.
Max said:I love you, Warmoth.
And that is the best representation of the carved top so far. Not sure how keen I am on the horn bevel, though.
Gregg said:This is pretty cool eh?.....
http://www.warmoth.com/Showcase/ShowcaseItem.aspx?i=pt1518&Body=2&Path=Body
Jmohill said:Giggity.
tfarny said:Yeah, slap a completed one together and put it on the front page.
