line6man
Epic Member
JimBeed said:ah ok, well ill get a 4 pole 5 way somewhere then, but ive had a thought, would wiring the two in seperate volume and tone as in two seperate circuits, with the bridge having a push push to change the parallel/series work? then solder the wires that go to the jack from each circuit seperately, along side the ground? just having looked at my options i have three, each with flaws:
1. rotary switch, looks complex wiring for a first time build
2. toggle switches, easier to wire, but need a smaller hole drilled, thus meaning id have to chance ruining a bit of the finish, though i would cover it and everything.
3. seperate circuits with a push/push on the volume for the bridge(cheap s1 switch), no clue if i could actually do that, and whether it would be safe to.
4. the only other thing is the five way selector switch that strats use, but that means getting someone else to rout a slot for it.
I would much rather just do two volumes and a 3 way switch, with a series/parallel for the Powerbucker than the rotary thing.
1. Just go for it. It's not that difficult if you have patience.
2. No comment.
3. Yeah, you could do a series/parallel for the bridge pickup as a push/pull no problem.
4. FWIW, Stew Mac sells a 4P5T Strat switch.
