stratamania
Mythical Status
Inserts would definitely do it, but then again the buttons are easy enough to replace.
Cagey said:The zero fret needs to be the same size or larger than what's installed for the balance of the neck. Installing a .043" high fret at the zero position when the rest of the neck is fretted with something .047" tall means you're going to have to set the bridge pretty tall just to clear the first fret, and your action will deteriorate (grow) the further down the 'board you go no matter what you do with the bridge/truss rod.
If it was me, I'd put in something slightly larger, like .050" or so. Gives you room to do maintenance down the road if necessary, but still allows for some wicked close action.
That said, if you want a piece of fretwire with a .047" crown, I've got you covered. Lemme know if you want gold or stainless and PM me an address.
stratamania said:That jig is looking good.
Cagey said:stratamania said:That jig is looking good.
It is, isn't it? Plus, the auxiliary jig for stringing it up allows the neck to be played, which I find to be invaluable. Removes a whole lotta variables and questions instantly if you bolt the neck onto something and it doesn't behave itself.
Exactly what i figured. Can't understand why ZeroGlide would supply such small frets.Cagey said:The zero fret needs to be the same size or larger than what's installed for the balance of the neck. Installing a .043" high fret at the zero position when the rest of the neck is fretted with something .047" tall means you're going to have to set the bridge pretty tall just to clear the first fret, and your action will deteriorate (grow) the further down the 'board you go no matter what you do with the bridge/truss rod.
Like I said, I tried the .051" but it left me with .025" clearance at the first fret. Seems like that's enough to affect intonation playing "Cowboy" chords.Cagey said:If it was me, I'd put in something slightly larger, like .050" or so. Gives you room to do maintenance down the road if necessary, but still allows for some wicked close action.
I was hoping you might say that. I sent you my address, thanks!Cagey said:That said, if you want a piece of fretwire with a .047" crown, I've got you covered. Lemme know if you want gold or stainless and PM me an address.
Pretty sure they're nickle.stratamania said:Just curious does the zero glide, have nickel fret wire or stainless. If it's nickel getting a piece of stainless from Cagey may save time later down the road in any case.
I see where you're going, but that would also assume that you could set the action to .013" at the 12th, which of course you can't. How much higher than the height of the first fret do you generally cut the bottom of the nut slot? Is it the same across all six strings?Cagey said:Yes, but let's work in a perfect world for a moment, where the strings are parallel to a perfectly straight neck. That .013" clearance at the first fret on the JM is set by the nut slot. In other words, the bottom of the slot is cut FretCrownHeight + StringClearance up from the surface of the fretboard. On the Tele neck, that clearance is supposed to be set by the zero fret crown height. So, if #0 FretCrownHeight = .051" and #1 FretCrownHeight = .047", you should have StringClearance = .004"
I feel the same way. I absolutely loved the feel of the mid 60's Gretsch Anniversary model I used to play. I think the zero fret was a big part of why it played so nice. This ZeroGlide is a chance for me to see if I'm right. If not, I have a Tusq on standby.Cagey said:....The zero nut thing never being accepted here due to its early appearance on budget instruments is something of a tragedy for players, techs and luthiers alike.
